你所需要的
Separate the front and back pieces of the cameras plastic casing using a spudgerm here.
WARNING: When pulling the front plastic casing, be careful of the wire that are connected to the aperture control
Use minimal force so that the plastic casing does not break
When separating the small silver sliding indicator for view/off/playback may fall out
The plastic viewing window located on the top of the camera may also become lose and fall out
Remove copper sheet from the front paneling and back.
You will need to use a spudger to unsolder the copper paneling
Use the spudger to separate the back circuit board from the camera
The picture viewing screen is glued to the backing as well as wired in with pink and white wires.
Exert minimal force required to pull the screen loose from the camera
Remove the pink and white wiring from the internal paneling. These wires are soldered in
Remove the orange data hookup cable which feeds into the back circuit board
