跳转到主内容
Epomaker SK64S Keyboard Switches Replacement
你所需要的
  1. Epomaker SK64S Keyboard Switches Replacement, Epomaker SK64S Keyboard Switches: 步骤 1 中的图像 1,3 Epomaker SK64S Keyboard Switches Replacement, Epomaker SK64S Keyboard Switches: 步骤 1 中的图像 2,3 Epomaker SK64S Keyboard Switches Replacement, Epomaker SK64S Keyboard Switches: 步骤 1 中的图像 3,3
    • Do not disassemble keyboard if it is connected to a power source.
    • Unplug the power cable.
  2. Epomaker SK64S Keyboard Switches Replacement: 步骤 2 中的图像 1,3 Epomaker SK64S Keyboard Switches Replacement: 步骤 2 中的图像 2,3 Epomaker SK64S Keyboard Switches Replacement: 步骤 2 中的图像 3,3
    • Align the keycap puller with the keycap.
    • Pull the keycap straight out.
    • Remove all of the keys.
  3. Epomaker SK64S Keyboard Switches Replacement: 步骤 3 中的图像 1,3 Epomaker SK64S Keyboard Switches Replacement: 步骤 3 中的图像 2,3 Epomaker SK64S Keyboard Switches Replacement: 步骤 3 中的图像 3,3
    • Fill the plastic container with water.
    • Add two drops of dish soap.
    • Put in the keycaps.
    • Let the keycaps soak for 30 minutes.
  4. Epomaker SK64S Keyboard Switches Replacement: 步骤 4 中的图像 1,3 Epomaker SK64S Keyboard Switches Replacement: 步骤 4 中的图像 2,3 Epomaker SK64S Keyboard Switches Replacement: 步骤 4 中的图像 3,3
    • Take the keycaps out.
    • Place them on a paper towel.
    • Let the keycaps dry out.
  5. Epomaker SK64S Keyboard Switches Replacement: 步骤 5 中的图像 1,3 Epomaker SK64S Keyboard Switches Replacement: 步骤 5 中的图像 2,3 Epomaker SK64S Keyboard Switches Replacement: 步骤 5 中的图像 3,3
    • Use an alcohol wipe to soak the cotton swab.
    • Clean the board by running the cotton swab along the board.
  6. Epomaker SK64S Keyboard Switches Replacement: 步骤 6 中的图像 1,3 Epomaker SK64S Keyboard Switches Replacement: 步骤 6 中的图像 2,3 Epomaker SK64S Keyboard Switches Replacement: 步骤 6 中的图像 3,3
    • Align the switch puller with the faulty switch.
    • Pull the switch straight out.
  7. Epomaker SK64S Keyboard Switches Replacement: 步骤 7 中的图像 1,3 Epomaker SK64S Keyboard Switches Replacement: 步骤 7 中的图像 2,3 Epomaker SK64S Keyboard Switches Replacement: 步骤 7 中的图像 3,3
    • Align the new key switch.
    • Push the key switch straight down.
  8. Epomaker SK64S Keyboard Switches Replacement: 步骤 8 中的图像 1,3 Epomaker SK64S Keyboard Switches Replacement: 步骤 8 中的图像 2,3 Epomaker SK64S Keyboard Switches Replacement: 步骤 8 中的图像 3,3
    • Align the keycap.
    • Push the keycap straight down.
    • Replace all the keycaps.
结论
Type away!
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 11
总计 807
