跳转到主内容
Epiphone Les Paul Special Input Jack Replacement
你所需要的
  1. Epiphone Les Paul Special Input Jack Replacement, Input Jack: 步骤 1 中的图像 1,1
    • Using a Phillips #1 screwdriver, remove the four 7 mm screws holding the input jack cover.
  2. Epiphone Les Paul Special Input Jack Replacement: 步骤 2 中的图像 1,1
    • With a 12 mm wrench, remove the nut holding the input jack in place.
  3. Epiphone Les Paul Special Input Jack Replacement: 步骤 3 中的图像 1,2 Epiphone Les Paul Special Input Jack Replacement: 步骤 3 中的图像 2,2
    • Lift off the tone control knob.
  4. Epiphone Les Paul Special Input Jack Replacement: 步骤 4 中的图像 1,1
    • Using an 11 mm wrench, remove the nut of the tone control.
  5. Epiphone Les Paul Special Input Jack Replacement: 步骤 5 中的图像 1,1
    • With a Phillips #1 screwdriver, remove the three 7 mm screws holding on the back plate.
  6. Epiphone Les Paul Special Input Jack Replacement: 步骤 6 中的图像 1,2 Epiphone Les Paul Special Input Jack Replacement: 步骤 6 中的图像 2,2
    • Pull out the tone control.
  7. Epiphone Les Paul Special Input Jack Replacement: 步骤 7 中的图像 1,2 Epiphone Les Paul Special Input Jack Replacement: 步骤 7 中的图像 2,2
    • Push the input jack through the body and pull it out.
  8. Epiphone Les Paul Special Input Jack Replacement: 步骤 8 中的图像 1,1
    • The soldering iron is very hot. Avoid contact with skin, as well as the body of the instrument. When not in use, place it on a soldering iron stand.
    • Desolder the wires from the input jack.
  9. Epiphone Les Paul Special Input Jack Replacement: 步骤 9 中的图像 1,1
    • Solder the wires to the input jack.
    • Repeat steps 7-1 in reverse order to put it all back together.
结论
To get everything back into its original place, follow steps 1-7 in reverse order.
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 19
过去 30 天: 77
总计 4,367
