跳转到主内容
Epiphone Les Paul Guitar String Replacement
你所需要的
  1. Epiphone Les Paul Guitar String Replacement, Guitar String: 步骤 1 中的图像 1,1
    • Loosen the first sting you would like to replace by turning the corresponding knob counter-clockwise.
    • Do NOT loosen/remove all strings at once! The lack of tension will cause the neck of the guitar to bend, and the guitar will have trouble staying in tune.
  2. Epiphone Les Paul Guitar String Replacement: 步骤 2 中的图像 1,1
    • Pull string away from the rest of the strings and snip it with the wire cutters.
    • String may go flying and will be sharp. Be careful.
  3. Epiphone Les Paul Guitar String Replacement: 步骤 3 中的图像 1,1
    • Remove the cut string from the bridge of the guitar and its corresponding spoke.
  4. Epiphone Les Paul Guitar String Replacement: 步骤 4 中的图像 1,2 Epiphone Les Paul Guitar String Replacement: 步骤 4 中的图像 2,2
    • Lead new string through bridge and then spoke. Leave plenty of slack in the string.
    • Strings will be color coded by the bead on the end of it, and the pack of strings will tell you which string goes where.
  5. Epiphone Les Paul Guitar String Replacement: 步骤 5 中的图像 1,2 Epiphone Les Paul Guitar String Replacement: 步骤 5 中的图像 2,2
    • Use your right hand to hold the slack near the bridge, and use your left hand to tightly pull the string through the spoke while turning the knob with the fingers of your left hand.
    • This may feel uncomfortable, and will also take the longest out of all the steps.
  6. Epiphone Les Paul Guitar String Replacement: 步骤 6 中的图像 1,1
    • Once the string starts getting tight and your right hand is no longer needed to hold slack, start tuning the string to the note you want it at.
    • You can use a tuner or your ear. This site can prove to be helpful: How to Tune a Guitar
结论
Have fun playing with your new bright-sounding guitar.
9等其他人完成本指南。
Matthew Thomas
于02/24/15注册
335 声望
撰写一个指南
团队
Cal Poly, Team 24-3, Green Winter 2015 Cal Poly, Team 24-3, Green Winter 2015 的会员
CPSU-GREEN-W15S24G3
5 名成员
创作了5篇指南
一条评论
Thank you very much. First time changing the strings to a guitar, unfortunately I'm a moron and broke the D String :\
Luigi - 回复
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 62
过去 30 天: 239
总计 17,773
