跳转到主内容
Epiphone ES-335 PRO Pickguard Replacement
你所需要的
  1. Epiphone ES-335 PRO Pickguard Replacement, Pickguard: 步骤 1 中的图像 1,1
    • Locate the screw closest to the neck of the guitar.
    • Use a phillips head #2 screwdriver to completely unscrew the 1.0 mm length screw.
    • Be sure to keep any screws together as you will use them again, unless the replacement pickguard has its own screws.
  2. Epiphone ES-335 PRO Pickguard Replacement: 步骤 2 中的图像 1,2 Epiphone ES-335 PRO Pickguard Replacement: 步骤 2 中的图像 2,2
    • Using a phillips head #2 screwdriver, completely unscrew the 1.0 mm length screw.
    • Gently lift the pickguard off the body of the guitar.
结论
一条评论
very nice and simple demo, but where would you get a new pickguard, as Epiphone will not
supply them and other aftermarket guards will not fit.
peterattard1 - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 91
总计 4,597
