跳转到主内容
Engine Brake Disassembly
你所需要的
  1. Engine Brake Disassembly, Remove spring and brackets: 步骤 1 中的图像 1,1
    • Remove the return spring by using needle nose pliers, a screwdriver, or other device. I removed the spring by the end of the front bracket (away from the mower handle). Lift up and away from the bracket, and the spring should come out.
    • Beware! The spring is very strong and injury could result if proper care is not exercised.
    • Remove the two bolts using a 7/16 socket.
  2. Engine Brake Disassembly, Remove alternator wire: 步骤 2 中的图像 1,1
    • Push the metal tab closest to the black wire down
    • While pushing the tab down, pull the black wire out of the clip.
    • Disassembly is complete!
结论
Jacob Micallef
于03/06/17注册
993 声望
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 407
