跳转到主内容
Engage Wired Optical Mouse Top and Outer Shell Removal
你所需要的
  1. Engage Wired Optical Mouse Top and Outer Shell Removal, Engage Wired Optical Mouse Top and Outer Shell Removal: 步骤 1 中的图像 1,1
    • Flip the mouse over and peel off the stickers on the perimeter of the bottom of the mouse.
  2. Engage Wired Optical Mouse Top and Outer Shell Removal: 步骤 2 中的图像 1,1
    • Use the Phillips #1 screwdriver to remove four 5 mm screws from the bottom of the mouse.
    • Use the Phillips #1 screwdriver to remove the two 9 mm screws from the bottom of the mouse.
  3. Engage Wired Optical Mouse Top and Outer Shell Removal: 步骤 3 中的图像 1,3 Engage Wired Optical Mouse Top and Outer Shell Removal: 步骤 3 中的图像 2,3 Engage Wired Optical Mouse Top and Outer Shell Removal: 步骤 3 中的图像 3,3
    • Grab the top shell of the mouse and lift up to remove.
  4. Engage Wired Optical Mouse Top and Outer Shell Removal: 步骤 4 中的图像 1,1
    • The capacitors on this board can release stored electrical energy if touched.
    • Touch your capacitor discharge tool to the capacitor leads on the board to release the stored energy. If leads are inaccessible, wait until you've removed the board from the mouse body.
  5. Engage Wired Optical Mouse Top and Outer Shell Removal: 步骤 5 中的图像 1,2 Engage Wired Optical Mouse Top and Outer Shell Removal: 步骤 5 中的图像 2,2
    • Use a spudger to pry underneath the white plug and pop it out to disconnect the upper board from the lower board.
结论
2等其他人完成本指南。
royceeklund
于01/18/13注册
115 声望
创作了3篇指南
团队
Cal Poly, Team 18-36, Regan Winter 2013 Cal Poly, Team 18-36, Regan Winter 2013 的会员
CPSU-REGAN-W13S18G36
3 名成员
创作了30篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 131
总计 3,952
