跳转到主内容
Energizer Power and Play Wireless Charging System for Wii Batteries Replacement
你所需要的
  1. Energizer Power and Play Wireless Charging System for Wii Batteries Replacement, Energizer Power and Play Induction Charging Battery Pack: 步骤 1 中的图像 1,2 Energizer Power and Play Wireless Charging System for Wii Batteries Replacement, Energizer Power and Play Induction Charging Battery Pack: 步骤 1 中的图像 2,2
    • Remove battery pack from the Wii Remote and locate the two screws between the batteries. Remove these and put them asside.
    • The batteries used by the factory are underpowered 600mAh rechargeables. I highly recommend replacing them with at least 850mAh ones, the higher the better.
  2. Energizer Power and Play Wireless Charging System for Wii Batteries Replacement: 步骤 2 中的图像 1,1
    • Pull out the battery from the case. It should slide out easily.
  3. Energizer Power and Play Wireless Charging System for Wii Batteries Replacement: 步骤 3 中的图像 1,1
    • Using your fingernail or a small screwdriver, carefully separate the two halves of the battery casing. These aren't glued and should separate with little effort.
  4. Energizer Power and Play Wireless Charging System for Wii Batteries Replacement: 步骤 4 中的图像 1,1
    • Remove the two batteries, noting their orientation.
    • Clean up any leaking battery acid and/or corrosion.
    • Out of the dozen or so battery packs I have repaired, every single one had failed due to corrosion. This occurred even in units that were just a few months old.
  5. Energizer Power and Play Wireless Charging System for Wii Batteries Replacement: 步骤 5 中的图像 1,1
    • Once the contacts and compartment are clean, insert your new rechargeable batteries.
  6. Energizer Power and Play Wireless Charging System for Wii Batteries Replacement: 步骤 6 中的图像 1,1
    • Re-insert the screws. The battery pack will only fit in one direction.
    • While you are at it, clean the outer contacts and bend them out a little. This can help eliminate remotes having poor battery life.
    I would love to repair my RVL-003 controller but my battery pack has a different battery item #87048-E-14 top half of battery case is blue bottom half molded to back cover of controller is white have you ever changed out this type without destroying it? Can the battery case be split and change out batteries?
    Rick kroske - 回复
结论
You should now have a working battery pack. Insert back into the Wii Remote and place on the charger. Allow it to get a good full initial charge in order to extend your battery life.
Enjoy your "non-reparable" repaired induction charging system.
8等其他人完成本指南。
Arcane Scroll
于12/10/13注册
877 声望
创作了2篇指南
2条评论
Wow, that explains it. So many complaints about the energizer inductive batteries dying quickly. They take a product meant for two AA and replace it with two AAA's. Yep, that'll limit your playing time...
Mike Propp - 回复
Easy to do! Just waiting to see if it will charge. If not, it was worth the shot. Thank you!
martinlu82 - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 32
过去 30 天: 147
总计 32,914
