跳转到主内容
Enabot EBO SE Speaker Replacement
你所需要的
  1. Enabot EBO SE Speaker Replacement, Wheel Assembly: 步骤 1 中的图像 1,1
    • Gently turn the robot upside down.
    • Place the robot on a stable surface to prevent it from rolling or falling.
  2. Enabot EBO SE Speaker Replacement: 步骤 2 中的图像 1,3 Enabot EBO SE Speaker Replacement: 步骤 2 中的图像 2,3 Enabot EBO SE Speaker Replacement: 步骤 2 中的图像 3,3
    • Use a flathead 2.5 mm screwdriver to remove the 5.7 mm screw from the wheels.
    • A tool should have been provided in the box for this purpose.
  3. Enabot EBO SE Speaker Replacement: 步骤 3 中的图像 1,2 Enabot EBO SE Speaker Replacement: 步骤 3 中的图像 2,2
    • Pull the wheel assembly towards you so it comes straight off without resistance.
    • If there is resistance, make sure to apply gentle force when pulling as it can get damaged with too much force.
  4. Enabot EBO SE Speaker Replacement, Lower Housing: 步骤 4 中的图像 1,2 Enabot EBO SE Speaker Replacement, Lower Housing: 步骤 4 中的图像 2,2
    • Use a Torx screwdriver to remove the four 9 mm screws from the assembly.
  5. Enabot EBO SE Speaker Replacement: 步骤 5 中的图像 1,3 Enabot EBO SE Speaker Replacement: 步骤 5 中的图像 2,3 Enabot EBO SE Speaker Replacement: 步骤 5 中的图像 3,3
    • Use your fingernail to carefully press down and eject the Micro SD Card from the back of the Enabot.
    • Keep the Micro SD Card in a safe spot for later.
  6. Enabot EBO SE Speaker Replacement: 步骤 6 中的图像 1,2 Enabot EBO SE Speaker Replacement: 步骤 6 中的图像 2,2
    • Place the iFixit opening tool inside the Micro SD slot.
    • Very carefully apply pressure to the top of the slot and pry open the casing to separate the upper and lower housing.
  7. Enabot EBO SE Speaker Replacement: 步骤 7 中的图像 1,3 Enabot EBO SE Speaker Replacement: 步骤 7 中的图像 2,3 Enabot EBO SE Speaker Replacement: 步骤 7 中的图像 3,3
    • Using the iFixit opening tool or your fingernail, place it underneath the gray tab on the lower housing.
    • Lift the tab up and pull out the ribbon cable to disconnect it from the lower housing.
  8. Enabot EBO SE Speaker Replacement: 步骤 8 中的图像 1,3 Enabot EBO SE Speaker Replacement: 步骤 8 中的图像 2,3 Enabot EBO SE Speaker Replacement: 步骤 8 中的图像 3,3
    • There are two black and red wire connectors attached to the upper and lower housing.
    • Gently use your finger nails to lift up and disconnect both wires to fully separate the upper and lower housings.
  9. Enabot EBO SE Speaker Replacement, Battery: 步骤 9 中的图像 1,3 Enabot EBO SE Speaker Replacement, Battery: 步骤 9 中的图像 2,3 Enabot EBO SE Speaker Replacement, Battery: 步骤 9 中的图像 3,3
    • Use the iFixit opening tool or your fingernail to disconnect the cable by placing the edge underneath the gray tab.
    • Flip the tab up and pull the ribbon cable out.
    • Disconnect the red and blue wires from the daughterboard by using your finger nails to pull up on the connector to disconnect.
  10. Enabot EBO SE Speaker Replacement: 步骤 10 中的图像 1,3 Enabot EBO SE Speaker Replacement: 步骤 10 中的图像 2,3 Enabot EBO SE Speaker Replacement: 步骤 10 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove both 7.4 mm screws from the side of the battery's casing.
  11. Enabot EBO SE Speaker Replacement: 步骤 11 中的图像 1,2 Enabot EBO SE Speaker Replacement: 步骤 11 中的图像 2,2
    • Pull the battery casing upwards from the lower half of the assembly to remove it.
  12. Enabot EBO SE Speaker Replacement: 步骤 12 中的图像 1,2 Enabot EBO SE Speaker Replacement: 步骤 12 中的图像 2,2
    • Carefully remove the battery from the casing in order to replace.
  13. Enabot EBO SE Speaker Replacement, Speaker: 步骤 13 中的图像 1,3 Enabot EBO SE Speaker Replacement, Speaker: 步骤 13 中的图像 2,3 Enabot EBO SE Speaker Replacement, Speaker: 步骤 13 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove each 7.4 mm screw from either side of the speaker.
    • Make sure to apply gentle force so it won't damage any other part of the Enabot EBO SE.
  14. Enabot EBO SE Speaker Replacement: 步骤 14 中的图像 1,3 Enabot EBO SE Speaker Replacement: 步骤 14 中的图像 2,3 Enabot EBO SE Speaker Replacement: 步骤 14 中的图像 3,3
    • Remove the speaker from the battery casing.
结论
Kevin H.
于02/15/24注册
656 声望
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 9
总计 60
