跳转到主内容
Ematic eGlide 4 Side Button Array Replacement
你所需要的
  1. Ematic eGlide 4 Side Button Array Replacement, Rear Panel: 步骤 1 中的图像 1,1
    • Remove the 4.6mm Phillips #00 screw at the base of the device.
  2. Ematic eGlide 4 Side Button Array Replacement: 步骤 2 中的图像 1,1
    • Slide the rear panel away from the base parallel to the screen.
  3. Ematic eGlide 4 Side Button Array Replacement: 步骤 3 中的图像 1,2 Ematic eGlide 4 Side Button Array Replacement: 步骤 3 中的图像 2,2
    • Carefully remove the speakers from the rear panel.
    • Pull the speakers off of the rear panel.
  4. Ematic eGlide 4 Side Button Array Replacement, Side Button Array: 步骤 4 中的图像 1,1
    • Remove the 3 Phillips #00 4.5 mm screws from the side button array.
  5. Ematic eGlide 4 Side Button Array Replacement: 步骤 5 中的图像 1,2 Ematic eGlide 4 Side Button Array Replacement: 步骤 5 中的图像 2,2
    • Slide the grey ribbon wire connector clip away from the ribbon wire port on the motherboard using the pointed tip of a spudger. This process will unclip the wire from the motherboard to release connection.
    • You do not need to fully disconnect the ribbon wire clip from the ribbon wire port: the clip will stay attached in a loose fit.
    • Remove the ribbon wire from the ribbon wire port on the motherboard.
  6. Ematic eGlide 4 Side Button Array Replacement: 步骤 6 中的图像 1,1
    • Remove the side button array from the device.
结论
另外一个人完成了本指南。
Bailey Hughes
于03/22/15注册
617 声望
创作了6篇指南
团队
Baylor, Team 5-8, Williams Spring 2015 Baylor, Team 5-8, Williams Spring 2015 的会员
BU-WILLIAMS-S15S5G8
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 98
