跳转到主内容
Ematic Model FTABMP2 Case Replacement
你所需要的
  1. Ematic Model FTABMP2 Case Replacement, Case: 步骤 1 中的图像 1,2 Ematic Model FTABMP2 Case Replacement, Case: 步骤 1 中的图像 2,2
    • Use a spudger to pry open the case of your device to reveal the inside.
  2. Ematic Model FTABMP2 Case Replacement: 步骤 2 中的图像 1,2 Ematic Model FTABMP2 Case Replacement: 步骤 2 中的图像 2,2
    • Disconnect the LCD cable from the motherboard by pressing together the two sides of the clamp to separate the device into two.
  3. Ematic Model FTABMP2 Case Replacement: 步骤 3 中的图像 1,1
    • Use the spudger to pry the LCD from the clamps holding it to the case.
  4. Ematic Model FTABMP2 Case Replacement: 步骤 4 中的图像 1,2 Ematic Model FTABMP2 Case Replacement: 步骤 4 中的图像 2,2
    • If you need to remove the back part of the casing, after disconnecting the LCD display from the motherboard, remove the screws holding down the motherboard. Remove the plastic power and volume buttons. remove the two side grips of the device.
  5. Ematic Model FTABMP2 Case Replacement: 步骤 5 中的图像 1,2 Ematic Model FTABMP2 Case Replacement: 步骤 5 中的图像 2,2
    • Remove the motherboard, speaker, and battery as a whole, which leaves just the back casing of the device.
结论
Timothy
于01/21/15注册
505 声望
创作了5篇指南
团队
USF Tampa, Team 9-2, Brown Winter 2015 USF Tampa, Team 9-2, Brown Winter 2015 的会员
USFT-BROWN-W15S9G2
5 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 165
