跳转到主内容
Ematic Model FTABMP2 Battery Replacement
你所需要的
  1. Ematic Model FTABMP2 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Ematic Model FTABMP2 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Use a spudger to pry open the case. Do this on the long side of the case. This will reveal the inside.
  2. Ematic Model FTABMP2 Battery Replacement: 步骤 2 中的图像 1,2 Ematic Model FTABMP2 Battery Replacement: 步骤 2 中的图像 2,2
    • Disconnect the LCD cable from the motherboard by pressing together the two sides of the clamp to separate the device into two.
  3. Ematic Model FTABMP2 Battery Replacement: 步骤 3 中的图像 1,2 Ematic Model FTABMP2 Battery Replacement: 步骤 3 中的图像 2,2
    • First, Remove the screws holding down the motherboard. Then remove the plastic power and volume buttons.
    • Next, remove the two side grips of the device. Now, you can remove the motherboard, speaker, and battery as one from the device.
  4. Ematic Model FTABMP2 Battery Replacement: 步骤 4 中的图像 1,1
    • Unsolder the gray, black, and red wires from the motherboard to release the battery.
结论
Timothy
于01/21/15注册
505 声望
创作了5篇指南
团队
USF Tampa, Team 9-2, Brown Winter 2015 USF Tampa, Team 9-2, Brown Winter 2015 的会员
USFT-BROWN-W15S9G2
5 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 273
