跳转到主内容
Ematic Genesis 2 Screen Replacement
你所需要的
  1. Ematic Genesis 2 Screen Replacement, Screen: 步骤 1 中的图像 1,2 Ematic Genesis 2 Screen Replacement, Screen: 步骤 1 中的图像 2,2
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
  2. Ematic Genesis 2 Screen Replacement: 步骤 2 中的图像 1,3 Ematic Genesis 2 Screen Replacement: 步骤 2 中的图像 2,3 Ematic Genesis 2 Screen Replacement: 步骤 2 中的图像 3,3
    • Remove all four screws surrounding the battery with a Phillips Head Screwdriver.
    • Carefully remove the battery from the device using the Metal Spudger tool to gently separate the battery by wedging it between the device and the battery.
  3. Ematic Genesis 2 Screen Replacement: 步骤 3 中的图像 1,2 Ematic Genesis 2 Screen Replacement: 步骤 3 中的图像 2,2
    • Remove the three screws surrounding the circuit board using the Phillips Head Screwdriver.
    • Remove the circuit board from the device by uncliping the copper flexible PCB ribbon cable from the circuit board.
  4. Ematic Genesis 2 Screen Replacement: 步骤 4 中的图像 1,1
    • Use the Small Pointed Metal Spudger to separate the LED screen from the front screen by gently wedging the spudger between the screen and the device.
  5. Ematic Genesis 2 Screen Replacement: 步骤 5 中的图像 1,1
    • Remove the glass from the front casing by using the metal spudger to break it free from the device. (It's held together by glue.)
    • Install the new screen.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 7
总计 440
