跳转到主内容
Ematic Genesis 2 Charging Port Replacement
你所需要的
  1. Ematic Genesis 2 Charging Port Replacement, Charging Port: 步骤 1 中的图像 1,2 Ematic Genesis 2 Charging Port Replacement, Charging Port: 步骤 1 中的图像 2,2
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
  2. Ematic Genesis 2 Charging Port Replacement: 步骤 2 中的图像 1,3 Ematic Genesis 2 Charging Port Replacement: 步骤 2 中的图像 2,3 Ematic Genesis 2 Charging Port Replacement: 步骤 2 中的图像 3,3
    • Remove all four screws surrounding the battery with the Phillips head screwdriver.
    • Carefully remove the battery from the device using the Metal Spudger tool to gently separate the battery by wedging it between the device and the battery.
  3. Ematic Genesis 2 Charging Port Replacement: 步骤 3 中的图像 1,2 Ematic Genesis 2 Charging Port Replacement: 步骤 3 中的图像 2,2
    • Remove both screws on either side of the audio jack using the Philips head screwdriver.
    • Detach audio jack from device.
  4. Ematic Genesis 2 Charging Port Replacement: 步骤 4 中的图像 1,2 Ematic Genesis 2 Charging Port Replacement: 步骤 4 中的图像 2,2
    • Remove the 3 screws surrounding the circuit board using the Philips head screwdriver.
    • Carefully disconnect the circuit board from the device by detaching the copper flexible PCB ribbon cable.
  5. Ematic Genesis 2 Charging Port Replacement: 步骤 5 中的图像 1,2 Ematic Genesis 2 Charging Port Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use a soldering iron to heat the solder holding the charging port to the circuit board.
    • Remove the charging port from board using tweezers.
  6. Ematic Genesis 2 Charging Port Replacement: 步骤 6 中的图像 1,1
    • Solder replacement port into place.
    • Make sure all connections match original.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 7
过去 30 天: 10
总计 551
