跳转到主内容
Ematic Genesis 2 Battery Replacement
你所需要的
  1. Ematic Genesis 2 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Ematic Genesis 2 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
  2. Ematic Genesis 2 Battery Replacement: 步骤 2 中的图像 1,3 Ematic Genesis 2 Battery Replacement: 步骤 2 中的图像 2,3 Ematic Genesis 2 Battery Replacement: 步骤 2 中的图像 3,3
    • Remove all four screws surrounding the battery with a Phillips Head Screwdriver.
    • Carefully remove the battery from the device using the Metal Spudger tool to gently separate the battery by wedging it between the device and the battery.
  3. Ematic Genesis 2 Battery Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    Desoldering Pump
    $3.99
    购买
    • Carefully remove the solder that connects the battery wires to the device using the solder sucker tool and a soldering iron.
    • When using the soldering iron to heat the existing solder, do not damage the device or surrounding connections.
    • Once all solder is gone, remove the wires from the device to free the battery.
  4. Ematic Genesis 2 Battery Replacement: 步骤 4 中的图像 1,1
    • Use the soldering iron to solder the wires from the new battery to the device.
    • The connections from the wires should go in order from left to right being white, black (negative), and red (positive), respectively.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 9
总计 349
