跳转到主内容
Ematic Genesis 2 Audio Jack Repair
你所需要的
  1. Ematic Genesis 2 Audio Jack Repair, Ematic Genesis 2 Audio Jack Repair: 步骤 1 中的图像 1,2 Ematic Genesis 2 Audio Jack Repair, Ematic Genesis 2 Audio Jack Repair: 步骤 1 中的图像 2,2
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
  2. Ematic Genesis 2 Audio Jack Repair: 步骤 2 中的图像 1,3 Ematic Genesis 2 Audio Jack Repair: 步骤 2 中的图像 2,3 Ematic Genesis 2 Audio Jack Repair: 步骤 2 中的图像 3,3
    • Remove all four screws surrounding the battery with the screwdriver.
    • Carefully remove the battery from the device using the Metal Spudger tool to gently separate the battery by wedging it between the device and the battery.
  3. Ematic Genesis 2 Audio Jack Repair: 步骤 3 中的图像 1,1
    • Remove the two screws that hold the audio jack in place. Carefully lift the audio jack out of the compartment.
    • Use compressed air or a Q-tip to gently clear out the dirt from the inside of the audio jack. This will help make sure future connections are clear.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 9
总计 156
