简介
Following our troubleshooting page, you have diagnosed the problem to be a defective speaker.
你所需要的
First, be sure to power off the device.
Carefully pry open the device. Note the plastic tabs in the image that hold the device together.
Locate the speaker in the bottom right hand side of the device. Note the red and black wires attaching the speaker to the motherboard.
Carefully remove the soldered wires from the motherboard. Note the positive and negative symbol where the red and black wires are soldered to on the motherboard.
Carefully, solder the new speaker wires to the motherboard in the same fashion as the old speaker. The red wire to the '+' symbol and the black wire to the '-' symbol.
Once the solder points have cooled, position the speaker into the speaker housing on the back bezel as shown in the image.
