跳转到主内容
Ematic Funtab FTABXXX Speaker Replacement
你所需要的
  1. Ematic Funtab FTABXXX Speaker Replacement, Opening the Device: 步骤 1 中的图像 1,2 Ematic Funtab FTABXXX Speaker Replacement, Opening the Device: 步骤 1 中的图像 2,2
    • First, be sure to power off the device.
    • Carefully pry open the device. Note the plastic tabs in the image that hold the device together.
  2. Ematic Funtab FTABXXX Speaker Replacement, Locating the speaker: 步骤 2 中的图像 1,1
    • Locate the speaker in the bottom right hand side of the device. Note the red and black wires attaching the speaker to the motherboard.
  3. Ematic Funtab FTABXXX Speaker Replacement, Removing the old speaker: 步骤 3 中的图像 1,1
    • Carefully remove the soldered wires from the motherboard. Note the positive and negative symbol where the red and black wires are soldered to on the motherboard.
  4. Ematic Funtab FTABXXX Speaker Replacement, Soldering the new speaker: 步骤 4 中的图像 1,1
    • Carefully, solder the new speaker wires to the motherboard in the same fashion as the old speaker. The red wire to the '+' symbol and the black wire to the '-' symbol.
  5. Ematic Funtab FTABXXX Speaker Replacement, Positioning the speaker: 步骤 5 中的图像 1,1
    • Once the solder points have cooled, position the speaker into the speaker housing on the back bezel as shown in the image.
结论
团队
USF Tampa, Team 6-3, Brown Winter 2015 USF Tampa, Team 6-3, Brown Winter 2015 的会员
USFT-BROWN-W15S6G3
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 6
总计 168
