跳转到主内容
Ematic Funtab FTABXXX Power and Sound Buttons Replacement
你所需要的
  1. Ematic Funtab FTABXXX Power and Sound Buttons Replacement, Power and Sound Buttons: 步骤 1 中的图像 1,2 Ematic Funtab FTABXXX Power and Sound Buttons Replacement, Power and Sound Buttons: 步骤 1 中的图像 2,2
    • Before opening the device make sure the device is powered down if possible.
    • Using a spading tool open the device along the clips.
  2. Ematic Funtab FTABXXX Power and Sound Buttons Replacement: 步骤 2 中的图像 1,2 Ematic Funtab FTABXXX Power and Sound Buttons Replacement: 步骤 2 中的图像 2,2
    • Locate the plastic power button.
    • Locate the plastic sound button.
  3. Ematic Funtab FTABXXX Power and Sound Buttons Replacement: 步骤 3 中的图像 1,1
    • Once the power button has been located place it in the appropriate spot as indicated by the picture. Make sure that the plastic button will connect with the black button when pressed.
  4. Ematic Funtab FTABXXX Power and Sound Buttons Replacement: 步骤 4 中的图像 1,2 Ematic Funtab FTABXXX Power and Sound Buttons Replacement: 步骤 4 中的图像 2,2
    • Once the sound button has been located place it in the correct spot as indicated by the picture.
    • Make sure the plastic sound button will connect with the small black buttons when pressed down.
结论
Xavier Smith
于01/21/15注册
210 声望
创作了2篇指南
团队
USF Tampa, Team 6-3, Brown Winter 2015 USF Tampa, Team 6-3, Brown Winter 2015 的会员
USFT-BROWN-W15S6G3
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 9
总计 315
