跳转到主内容
Ematic FunTab 3 Back Panel Replacement
你所需要的
  1. Ematic FunTab 3 Back Panel  Replacement, Back Panel: 步骤 1 中的图像 1,3 Ematic FunTab 3 Back Panel  Replacement, Back Panel: 步骤 1 中的图像 2,3 Ematic FunTab 3 Back Panel  Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Turn off the device before starting
    • To prevent damage, open the device on the side without the buttons.
    • Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
    • Slide the plastic opening tool down the long side of the device.
    • Insert tool again and slide it down the long slide of the case a second time.
  2. Ematic FunTab 3 Back Panel  Replacement: 步骤 2 中的图像 1,1
    • Pull the back panel away from the screen.
结论
Harrison Lee
于07/12/18注册
85 声望
撰写一个指南
团队
UW Tacoma, Team S1-G5, Cardinal Summer 2018 UW Tacoma, Team S1-G5, Cardinal Summer 2018 的会员
UWT-CARDINAL-SU18S1G5
4 名成员
创作了12篇指南
1指南评论
Our funtab3 is not work because we want to work but Anything is not work. We see a tiny crack
Adelaida Lopez Arias - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 258
