简介
My wife's Elvie Stride got some milk inside and suddenly stopped working. I was able to take it apart and disconnected the battery. After cleaning the milk off and letting everything dry, it charged properly and started working again.
This isn't a proper disassembly guide, but hopefully it gives you the courage to pop yours apart if it stops working!
Take off the rubber sleeve around the case.
The two halves of the clamshell are held together by about 9 plastic snaps - no screws or glue.
A handful of guitar picks and gentle prying on each side should be sufficient to pop it open.
3等其他人完成本指南。
9条评论
my battery keeps disconnecting inside the hub, not sure how to fix it but that could be a common issue with them.
I didn't have a guitar pick on hand but was able to use an old gift card to open this up. Any credit card would work here.
what battery is used? is it a common size one can buy easily, with a standard connector?
It's a standard 18500 li-ion cell, nominally 2300mAh. I can't identify the connector but it looks similar to a Molex Pico-EZmate.
The connector is shrink-wrapped onto the battery, and could probably be removed and taped onto a new one.
The battery connector definitely comes away too easily from the board. If my wife's does it again, I'm thinking I'll see about using a dab of hot glue to see it down. It could damage it but only one way to find out. @angeladarby
Good luck
