跳转到主内容
Elenco Auto-Scan FM Radio Model FM-88K Capacitor 22 Replacement
你所需要的
    • Remove the battery and the antenna.
    • Pre-heat the soldering iron.
    • Place hot solder iron on thermal pad, capacitor lead, and the mound of solder until solder liquefies.
    • Apply desoldering pump to remove the solder from the circuit board.
    • Repeat the instructions to remove solder from the adjacent solder mound.
    • Gently remove the capacitor by pulling the two leads out of the circuit board.
    • Place the leads of the capacitor through designated holes of the circuit board.
    • Place solder iron on the thermal pad and the lead.
    • Once this is done wait a few seconds until both items heat up.
    • Once they are heated, apply the solder to the other side so that the solder iron and the solder are not directly touching.
    • Wait 3 to 5 seconds or until enough solder covers the whole pad and forms a nice mound.
    • Remove the solder, leaving the solder iron on the pad for 2 to three seconds, then remove the solder iron.
    • Repeat for the other lead.
    • Plug the battery in and attach the antenna to test the radio.
结论
4等其他人完成本指南。
Charles Riel
于10/10/14注册
218 声望
撰写一个指南
团队
Charlie Riel Charlie Riel 的会员
Community
1 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 9
总计 1,037
