跳转到主内容
Element GC-1020 Screen Replacement
你所需要的
  1. Element GC-1020 Screen  Replacement, Back Cover Replacement Guide: 步骤 1 中的图像 1,1
    • Unscrew the four screws (size: 3.175mm) on the left and right side of the Element Electronics GC-1020 device using the PH#0 screwdriver.
  2. Element GC-1020 Screen  Replacement: 步骤 2 中的图像 1,1
    • Carefully pull the back of the device (the silver portion) apart from the rest of the device.
    • If you pull back too forcefully the power button would move out of place.
  3. Element GC-1020 Screen  Replacement, Screen: 步骤 3 中的图像 1,1
    • Unscrew the bottom of left and right sides of the motherboard.
    • Notice these screws are slightly larger than the ones on the outside of the device.
  4. Element GC-1020 Screen  Replacement: 步骤 4 中的图像 1,2 Element GC-1020 Screen  Replacement: 步骤 4 中的图像 2,2
    • Carefully bend the plastic frame to remove the motherboard.
    • Be sure that the power button, stays attached to the outer frame, as moving the motherboard it may cause it to loosen.
  5. Element GC-1020 Screen  Replacement: 步骤 5 中的图像 1,3 Element GC-1020 Screen  Replacement: 步骤 5 中的图像 2,3 Element GC-1020 Screen  Replacement: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Detach the screen by disconnecting the thin piece of ribbon cable attached to the PCB (printed circuit board).
    • Use a pair of tweezers to carefully pull the ribbon from the circuit board.
    • Take care not to damage the ribbon, as you will need it intact to reattach your new screen.
  6. Element GC-1020 Screen  Replacement: 步骤 6 中的图像 1,3 Element GC-1020 Screen  Replacement: 步骤 6 中的图像 2,3 Element GC-1020 Screen  Replacement: 步骤 6 中的图像 3,3
    • Carefully pry apart the screen from the frame of the device.
    • Separate the two by peeling away the thin plastic layer that makes up the screen of the device.
    • If done correctly, your detached screen will look like this.
结论
2等其他人完成本指南。
Lashaun Noel
于09/25/15注册
591 声望
创作了5篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 10
总计 231
