跳转到主内容
Electrolux RM-275 Absorption Refrigerator Refrigerator Igniter and Spark Electrode Replacement
你所需要的
    • Isolate mains supply.
    • Isolate the vehicle 12V supply.
    • Isolate the gas supply
    • Remove access panels to gain access to the rear of the fridge
    • Remove cover from spark igniter module
    • Note the colour and position of the 4 wires to the igniter module (+, -, L and spark). Pull the wires from the spark igniter module terminals.
    • Remove the two screws holding the igniter module to the back panel of the fridge, and remove the igniter module.
    • If you wish to remove the spark electrode, remove the metal cover around the gas flame unit. To do this, slacken the screw holding the cover to the fridge rear panel. Also slacken the screw holding the two parts of the cover together. By careful manoevering you can remove the metal cover parts separately.
    • Remember where the thermocouple and spark electrode are located relative to the gas jet. Then slacken the screw securing the clamp which holds the spark electrode and thermocouple. Remove the spark electrode.
    • Fit the replacement spark electrode, with tip pointing downwards, at the correct location as remembered from the previous step. The electrode tip should be 5mm (3/16 in) from the metal gas jet. Adjust the thermocouple to its previous position and tighten the screw to secure the clamp.The thermocouple tip should be in the gas flame.
    • New line.
    • Adjust the thermocouple to its original position and tighten the screw to secure the clamp.The thermocouple tip should be in the gas flame. Don't replace the gas jet covers at this stage - it is useful to see the spark when testing the new igniter module.
    • Check if the old igniter cover will fit the replacement igniter module. It may be necessary to make a new cover. For the new igniter I used a small plastic box from a local electronics store (Maplin). Make a hole to pass the spark electrode wire, and a small cutout to allow the other 3 wires.
    • Drill holes in the box for fixing the igniter to the box. Use countersunk screws recessed so they do not protrude outside the box. Secure the igniter to the box with the countersunk screws, washers and nuts
    • Drill 2 holes in the box and secure the igniter and box assembly to the rear of the fridge as near as possible to the location of the old igniter module.
    • Connect the + and - wires to the terminals marked + and - . Connect the L wire to the terminal marked GL. Connect the spark terminal to thes terminal marked with the spark symbol.
    • Fit the box lid using the 4 screws supplied with the box
    • Turn on the igniter switch and check the lamp flashes and the spark tick sound is audible.
结论
另外一个人完成了本指南。
GrandadTom
于08/12/12注册
237 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 4,543
