跳转到主内容
Electrohome EAAC475 USB Port Replacement
你所需要的
  1. Electrohome EAAC475 USB Port Replacement, Battery: 步骤 1 中的图像 1,2 Electrohome EAAC475 USB Port Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the 10 mm Phillips #1 screw from the battery cover.
    • Remove the battery cover.
  2. Electrohome EAAC475 USB Port Replacement: 步骤 2 中的图像 1,1
    • Remove the flat lithium battery.
  3. Electrohome EAAC475 USB Port Replacement, Buttons: 步骤 3 中的图像 1,2 Electrohome EAAC475 USB Port Replacement, Buttons: 步骤 3 中的图像 2,2
    • Disconnect the radio from all power sources.
    • Remove the two 10 mm Phillips #1 screws from the bottom of the device.
    • Remove two 10 mm Phillips #1 screws from the back side of the device.
  4. Electrohome EAAC475 USB Port Replacement: 步骤 4 中的图像 1,3 Electrohome EAAC475 USB Port Replacement: 步骤 4 中的图像 2,3 Electrohome EAAC475 USB Port Replacement: 步骤 4 中的图像 3,3
    • Carefully and slowly pull the lower case away from the rest of the device.
    • Do not completely separate the lower case. There are several wires connecting the two halves of the device.
    • Flip the device over to access the button assembly.
    • Slowly remove the button contact board from the assembly.
  5. Electrohome EAAC475 USB Port Replacement: 步骤 5 中的图像 1,2 Electrohome EAAC475 USB Port Replacement: 步骤 5 中的图像 2,2
    • Remove the two 7 mm Phillips # 1 screws holding the buttons.
    • Remove the plastic buttons.
  6. Electrohome EAAC475 USB Port Replacement, USB Port: 步骤 6 中的图像 1,1
    • Locate the screw holding the USB circuit board in place.
    • Take a Philips head screwdriver and remove the 10 mm screw.
  7. Electrohome EAAC475 USB Port Replacement: 步骤 7 中的图像 1,1
    • Upon removing the screw, the circuit board should slide right out to look like this.
    • The USB port is to the right in this picture.
  8. Electrohome EAAC475 USB Port Replacement: 步骤 8 中的图像 1,1
    • Find the pins of the USB port that are soldered into the circuit board.
    • Compare the new port with the old port to be sure which pins to work with.
    • Take the soldering gun and heat up the pins one at a time.
    • If you are not familiar with soldering, consult a more skilled individual or at least a how-to guide.
    • Use solder wick with each pin to remove the solder.
    • Remove the USB port.
结论
另外一个人完成了本指南。
Sterling Fulk
于02/16/16注册
264 声望
创作了2篇指南
团队
IUPUI, Team 2-1, Harley Spring 2016 IUPUI, Team 2-1, Harley Spring 2016 的会员
IUPUI-HARLEY-S16S2G1
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 296
