跳转到主内容
Electrohome EAAC475 Speaker Replacement
你所需要的
  1. Electrohome EAAC475 Speaker Replacement, Battery: 步骤 1 中的图像 1,2 Electrohome EAAC475 Speaker Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the 10 mm Phillips #1 screw from the battery cover.
    • Remove the battery cover.
  2. Electrohome EAAC475 Speaker Replacement: 步骤 2 中的图像 1,1
    • Remove the flat lithium battery.
  3. Electrohome EAAC475 Speaker Replacement, Buttons: 步骤 3 中的图像 1,2 Electrohome EAAC475 Speaker Replacement, Buttons: 步骤 3 中的图像 2,2
    • Disconnect the radio from all power sources.
    • Remove the two 10 mm Phillips #1 screws from the bottom of the device.
    • Remove two 10 mm Phillips #1 screws from the back side of the device.
  4. Electrohome EAAC475 Speaker Replacement: 步骤 4 中的图像 1,3 Electrohome EAAC475 Speaker Replacement: 步骤 4 中的图像 2,3 Electrohome EAAC475 Speaker Replacement: 步骤 4 中的图像 3,3
    • Carefully and slowly pull the lower case away from the rest of the device.
    • Do not completely separate the lower case. There are several wires connecting the two halves of the device.
    • Flip the device over to access the button assembly.
    • Slowly remove the button contact board from the assembly.
  5. Electrohome EAAC475 Speaker Replacement: 步骤 5 中的图像 1,2 Electrohome EAAC475 Speaker Replacement: 步骤 5 中的图像 2,2
    • Remove the two 7 mm Phillips # 1 screws holding the buttons.
    • Remove the plastic buttons.
  6. Electrohome EAAC475 Speaker Replacement, Speaker: 步骤 6 中的图像 1,2 Electrohome EAAC475 Speaker Replacement, Speaker: 步骤 6 中的图像 2,2
    • Carefully and slowly detach one side from another.
    • Make sure the opposite sides are not separated completely.
    • Locate the speaker the inside of the back piece of the device
  7. Electrohome EAAC475 Speaker Replacement: 步骤 7 中的图像 1,1
    • Use the flat side of the spudger to remove the glue around the speaker.
    • This glue will need replacing when putting back the speaker.
  8. Electrohome EAAC475 Speaker Replacement: 步骤 8 中的图像 1,1
    • After removing all the glue around the speaker, slowly take out the speaker.
    • Be careful not to break anything surrounding the speaker while using the spudger since it is sharp.
  9. Electrohome EAAC475 Speaker Replacement: 步骤 9 中的图像 1,1
    • Detach the wires on the speaker and replace them with new ones.
结论
Ruolin Cai
于02/16/16注册
273 声望
创作了2篇指南
团队
IUPUI, Team 2-1, Harley Spring 2016 IUPUI, Team 2-1, Harley Spring 2016 的会员
IUPUI-HARLEY-S16S2G1
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 14
总计 411
