简介
Use this guide to replace a faulty display or fix the wire connection between the circuit board and the display in an electrohome EAAC475 .
你所需要的
Remove the 10 mm Phillips #1 screw from the battery cover.
Remove the battery cover.
Remove the two 10 mm Phillips #1 screws from the bottom of the device.
Remove two 10 mm Phillips #1 screws from the back side of the device.
Remove the two 8 mm Phillips screws supporting the circuit board.
Pull off the circuit board to access the panels below.
即将完成!
结论
