跳转到主内容
加入维修社区 - 创建账户
Electrical Wall Outlet Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Electrical Wall Outlet Replacement, Wall Outlet: 步骤 1 中的图像 1,2 Electrical Wall Outlet Replacement, Wall Outlet: 步骤 1 中的图像 2,2
    • Turn off electrical power from the breaker by switching off the breaker that is connected to the designated area.
    • Check power by plugging in rechargeable device and check if charging. If not charging, power to the wall is off.
  2. Electrical Wall Outlet Replacement: 步骤 2 中的图像 1,1
    • Remove the screw from the outlet plate using a flathead screwdriver.
  3. Electrical Wall Outlet Replacement: 步骤 3 中的图像 1,1
    • Remove plate from outlet using a Phillips screwdriver.
  4. Electrical Wall Outlet Replacement: 步骤 4 中的图像 1,1
    • Remove screws from outlet that are connected to the wall using a Phillips screwdriver.
  5. Electrical Wall Outlet Replacement: 步骤 5 中的图像 1,1
    • Remove wires from outlet by gently pulling them out of the outlet and wall.
  6. Electrical Wall Outlet Replacement: 步骤 6 中的图像 1,2 Electrical Wall Outlet Replacement: 步骤 6 中的图像 2,2
    • Connect wires to new outlet being sure to connected them to their designated port. They are labeled on the back of the outlet with: neutral, ground and hot.
    • Insert wire into the designated port and tighten with Phillips Screwdriver.
    • Neutral Wire- White
    • Ground Wire- Copper
    • Hot Wire- Black
  7. Electrical Wall Outlet Replacement: 步骤 7 中的图像 1,3 Electrical Wall Outlet Replacement: 步骤 7 中的图像 2,3 Electrical Wall Outlet Replacement: 步骤 7 中的图像 3,3
    • Reassemble the outlet as it was removed.
结论
5等其他人完成本指南。
团队
Texas Tech, Team 22-4, Rauch Spring 2016 Texas Tech, Team 22-4, Rauch Spring 2016 的会员
TTU-RAUCH-S16S22G4
2 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,237
