跳转到主内容
加入维修社区 - 创建账户
Electrical Plug Replacement
你所需要的
  1. Electrical Plug Replacement, Two-Pole Plug: 步骤 1 中的图像 1,2 Electrical Plug Replacement, Two-Pole Plug: 步骤 1 中的图像 2,2
    • Be sure to unplug the lamp.
    • Locate the damaged portion of wire.
    • Cut the damaged plug from the lamp cord one inch below the damaged area
  2. Electrical Plug Replacement: 步骤 2 中的图像 1,2 Electrical Plug Replacement: 步骤 2 中的图像 2,2
    • Separate the wire by gently pulling it apart.
    • The wire with the raised ribbing on the coating is the neutral wire.
    • The hot wire has a smooth coating.
  3. Electrical Plug Replacement: 步骤 3 中的图像 1,3 Electrical Plug Replacement: 步骤 3 中的图像 2,3 Electrical Plug Replacement: 步骤 3 中的图像 3,3
    • Strip the coating off the wire.
    • Expose 3/4" of the copper wire.
    • Twist the exposed copper wire so that there is no fraying.
    • Twisting the wires ensures the strongest connection and maximum safety.
  4. Electrical Plug Replacement: 步骤 4 中的图像 1,2 Electrical Plug Replacement: 步骤 4 中的图像 2,2
    • Loosen the screw and open the replacement plug.
    • The silver screw is the neutral connection, and the brass screw is the hot connection.
    • The different connections must be determined in order to properly wire the replacement plug.
  5. Electrical Plug Replacement: 步骤 5 中的图像 1,3 Electrical Plug Replacement: 步骤 5 中的图像 2,3 Electrical Plug Replacement: 步骤 5 中的图像 3,3
    • Wrap the neutral wire around the neutral screw. Tighten the screw to secure the wire.
    • Remember the neutral wire is the wire with raised ribbing on the coating.
    • Wrap the hot wire around the brass screw. Tighten the screw to secure the wire.
  6. Electrical Plug Replacement: 步骤 6 中的图像 1,2 Electrical Plug Replacement: 步骤 6 中的图像 2,2
    • Thread the cord so the plug will completely close.
    • Tighten the exterior screw to close the plug.
结论
If the lamp the does not work after replacing the plug, the issue may be located in the bulb housing or in the connections.
19等其他人完成本指南。
Tim Spellings
于07/17/15注册
583 声望
撰写一个指南
团队
Texas Tech, Team 3-2, Rauch SU 2015 Texas Tech, Team 3-2, Rauch SU 2015 的会员
TTU-RAUCH-SU15S3G2
3 名成员
创作了4篇指南
7指南评论
Passt - gute Anleitung
Martin Winter - 回复 分享
A version for 3 prong (North American) would be great
James Harrison - 回复 分享
https://www.noveltylights.com/coaxial-6-...
How would you repair a coaxial cord wire right where it enters the screw on part?
olgaocon - 回复 分享
what do you do if the replacement plug has no screws to open it?
Kristin Ladd - 回复 分享
Buy a plug that can be opened with a screw
Toon Konings - 分享
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 71
过去 30 天: 324
总计 54,021
