简介
Common reasons to replace an outlet are for cosmetic and functional purposes. Cosmetic reasons include scratches, cracks, chips, etc. Functional reasons to replace an outlet would include: an outlet is not providing power, an outlet is not holding plugs tightly, and an outlet does not have optional features such as USB ports. This guide shows how to replace a standard residential wall outlet.
你所需要的
Turn off the power to the outlets by switching off all breakers that are labelled "receptacle."
Alternatively, you can switch off all breakers.
Use a Duspol or any other Voltmeter to test if there is voltage at the contacts.
5等其他人完成本指南。
3条评论
pictures tell the story in the right manner, easy to do.
Thanks from Aria electical
This is a great step by step guide. I wish I had this a couple of years ago. I knocked myself off a ladder because I thought the power was off... didn't test it... and got super lucky. Don't be like me... spend the money on a voltage tester to make sure it isn't live.
if you are in the fullerton ca area and we can help... check us out at http://fullertonElectricpros.com
Michelle -
