跳转到主内容
Electric dryer defective drive belt Replacement
你所需要的
  1. Electric dryer defective drive belt Replacement, Defective Drive Belt: 步骤 1 中的图像 1,1
    • There are many brands of electric dryers out there, but fortunately their construction follows just a few basic designs. The one I'm describing is a 20 year old Canadian Eaton model, but some of the inexpensive models sold today have the same construction.
    • A good indicator that you are dealing with a similar model is the presence of three screws at the end of the drum, which you can see after opening the appliance door. In these appliances the drum is held in place by the axis connected by the three screws you can see in the picture and the friction pads at the front panel of the dryer.
    • The first thing you will want to do is reach behind the dryer and unplug it from the electric outlet.
  2. Electric dryer defective drive belt Replacement: 步骤 2 中的图像 1,2 Electric dryer defective drive belt Replacement: 步骤 2 中的图像 2,2
    • If the belt is not yet completely broken, you will need to disengage it from the motor an the tensioner. To do that, unscrew the service door at the back.
    • Inside the door you will see the drive belt, wrapped around the motor pulley and the tensioner. Reach inside the appliance, push down on the tensioner lever, and disengage the belt. Be careful not to cut yourself: there are sharp metal edges all around.
结论
5等其他人完成本指南。
Nick Ivanov
于10/09/11注册
2,290 声望
创作了3篇指南
2条评论
Just what I needed - now I have to get a new belt. Thanks for the info...
fmorgan - 回复
Update from previous comment - for fitting the new belt https://www.youtube.com/watch?v=4M1x0luY...
fmorgan - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 50
总计 4,583
