跳转到主内容
Electric Wheelchair Battery Replacement
  1. Electric Wheelchair Battery Replacement, Battery to Electric Wheelchair: 步骤 1 中的图像 1,3 Electric Wheelchair Battery Replacement, Battery to Electric Wheelchair: 步骤 1 中的图像 2,3 Electric Wheelchair Battery Replacement, Battery to Electric Wheelchair: 步骤 1 中的图像 3,3
    • Locate the two batteries under the back of the wheelchair.
    • Pull the first battery pack to where you can reach the red battery connector.
    • Be careful, the batteries are heavy.
  2. Electric Wheelchair Battery Replacement: 步骤 2 中的图像 1,2 Electric Wheelchair Battery Replacement: 步骤 2 中的图像 2,2
    • Disconnect the red battery connectors by pulling them apart.
  3. Electric Wheelchair Battery Replacement: 步骤 3 中的图像 1,2 Electric Wheelchair Battery Replacement: 步骤 3 中的图像 2,2
    • Remove the first and second battery from the wheelchair.
  4. Electric Wheelchair Battery Replacement: 步骤 4 中的图像 1,2 Electric Wheelchair Battery Replacement: 步骤 4 中的图像 2,2
    • Disconnect the black battery connectors by pulling them apart.
  5. Electric Wheelchair Battery Replacement: 步骤 5 中的图像 1,3 Electric Wheelchair Battery Replacement: 步骤 5 中的图像 2,3 Electric Wheelchair Battery Replacement: 步骤 5 中的图像 3,3
    • One at a time, disconnect the clips holding each battery case closed.
    • Open each case to reveal the battery inside.
  6. Electric Wheelchair Battery Replacement: 步骤 6 中的图像 1,3 Electric Wheelchair Battery Replacement: 步骤 6 中的图像 2,3 Electric Wheelchair Battery Replacement: 步骤 6 中的图像 3,3
    • Remove the old battery from each case.
    • Put one new battery into each plastic case the old batteries were removed from.
  7. Electric Wheelchair Battery Replacement: 步骤 7 中的图像 1,1
    • Reattach the clips on each of the battery's protective casings.
  8. Electric Wheelchair Battery Replacement: 步骤 8 中的图像 1,3 Electric Wheelchair Battery Replacement: 步骤 8 中的图像 2,3 Electric Wheelchair Battery Replacement: 步骤 8 中的图像 3,3
    • Place the first battery back into the holder under the wheelchair.
    • Make sure that it is pushed all the way to the front of the wheelchair.
    • Place the second battery back into the holder.
  9. Electric Wheelchair Battery Replacement: 步骤 9 中的图像 1,3 Electric Wheelchair Battery Replacement: 步骤 9 中的图像 2,3 Electric Wheelchair Battery Replacement: 步骤 9 中的图像 3,3
    • Reconnect the black battery connectors.
    • Do not connect the red connectors until the black are connected.
    • Reconnect the red battery connectors.
    • Check that the chair turns on and is fully charged.
终点
3等其他人完成本指南。
Paige Efting
于01/19/16注册
159 声望
撰写一个指南
团队
一条评论
I greatly enjoyed reading your article :) Please continue publishing helpful topics like this. Regards, from <a href="http://www.scootersnchairs.com">Scooters 'N Chairs</a>.
Justin Lubomirsky - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 63
总计 6,760
