跳转到主内容
Electric Stove Burners and Drip Pans Replacement
你所需要的
  1. Electric Stove Burners and Drip Pans Replacement, Burners and Drip Pans: 步骤 1 中的图像 1,1
    • Unplug the stove or turn off the breaker, if your stove does not allow you to unplug it.
  2. Electric Stove Burners and Drip Pans Replacement: 步骤 2 中的图像 1,3 Electric Stove Burners and Drip Pans Replacement: 步骤 2 中的图像 2,3 Electric Stove Burners and Drip Pans Replacement: 步骤 2 中的图像 3,3
    • Slide the burners out of the receptacle block.
    • The prongs attached to the burner in the second image fit the slots in the receptacle block in the third image.
  3. Electric Stove Burners and Drip Pans Replacement: 步骤 3 中的图像 1,1
    • Lift the drip pan out of the stove.
  4. Electric Stove Burners and Drip Pans Replacement: 步骤 4 中的图像 1,2 Electric Stove Burners and Drip Pans Replacement: 步骤 4 中的图像 2,2
    • Wipe the surface underneath the drip pan to clean it and ensure there are no food remnants
  5. Electric Stove Burners and Drip Pans Replacement: 步骤 5 中的图像 1,2 Electric Stove Burners and Drip Pans Replacement: 步骤 5 中的图像 2,2
    • If all the wires look satisfactory, add the new drip pan.
    • Ensure you have the burner with the open ring so the prongs reach the receptacle block.
  6. Electric Stove Burners and Drip Pans Replacement: 步骤 6 中的图像 1,1
    • Slide new burner through the receptacle.
    • Reassemble stove after.
终点
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 111
总计 4,210
