跳转到主内容
Electric Outlet Cover Replacement
你所需要的
  1. Electric Outlet Cover Replacement, Cover: 步骤 1 中的图像 1,1
    • Setup a workspace around the damaged/old electrical outlet cover you are replacing.
  2. Electric Outlet Cover Replacement: 步骤 2 中的图像 1,2 Electric Outlet Cover Replacement: 步骤 2 中的图像 2,2
    • Use the flathead screwdriver to remove the screw from the outlet.
    • Lefty loose-y righty tight-y.
  3. Electric Outlet Cover Replacement: 步骤 3 中的图像 1,3 Electric Outlet Cover Replacement: 步骤 3 中的图像 2,3 Electric Outlet Cover Replacement: 步骤 3 中的图像 3,3
    • Remove the faceplate off of the wall.
  4. Electric Outlet Cover Replacement: 步骤 4 中的图像 1,1
    • Now that the faceplate is removed clean up the interior and surrounding area of the outlet.
    • Be cautious as you clean the exposed outlet due to the electric current still running through it.
结论
To make sure the outlet cover is properly installed, try to move the faceplate around and plug in your devices to ensure the outlet still works
2等其他人完成本指南。
团队
CSU Los Angeles, Team S12-G22, Harris Fall 2020 CSU Los Angeles, Team S12-G22, Harris Fall 2020 的会员
CSULA-HARRIS-F20S12G22
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 58
过去 30 天: 251
总计 7,245
