跳转到主内容
加入维修社区 - 创建账户
Electric Eel Drain Cleaner Guide Spring Replacement
你所需要的
  1. Electric Eel Drain Cleaner Guide Spring Replacement, Remove the Guide Spring: 步骤 1 中的图像 1,3 Electric Eel Drain Cleaner Guide Spring Replacement, Remove the Guide Spring: 步骤 1 中的图像 2,3 Electric Eel Drain Cleaner Guide Spring Replacement, Remove the Guide Spring: 步骤 1 中的图像 3,3
    • Unplug your drain cleaner before starting this guide. Because this device may have been used in a septic setting, it should be cleaned and disinfected as much as possible before disassembly.
    • Wear gloves to protect your hands from injury when handling the cable.
    • Ensure the cable is completely retracted into the auto-feeder.
    • Twist the guide spring counter-clockwise to unscrew it from the auto-feeder.
    • Remove the guide spring.
结论
Tarun Thiruma
于11/20/19注册
39,525 声望
创作了134篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 20
总计 643
