跳转到主内容
加入维修社区 - 创建账户
Electric Bike Throttle Replacement
你所需要的
  1. Electric Bike Throttle Replacement, Brake: 步骤 1 中的图像 1,1
    • Before starting to disassemble your electric bike, turn the power off.
    • Remove the 3/32 inch Allen screw.
    • When removing Allen screw, make sure the driver is well seated because they are simple to strip.
  2. Electric Bike Throttle Replacement, Throttle: 步骤 2 中的图像 1,1
    • Locate the throttle Allen screw.
    • Remove the 5/64 inch Allen screw.
  3. Electric Bike Throttle Replacement, Throttle: 步骤 3 中的图像 1,1
    • Slide the Throttle off.
    • When removing the throttle, be careful. Remove it slowly to avoid damaging the wire.
  4. Electric Bike Throttle Replacement, Control Box: 步骤 4 中的图像 1,1
    • Remove the following screws.
    • 2 mm Philips screws.
  5. Electric Bike Throttle Replacement: 步骤 5 中的图像 1,1
    • Open up the control box.
  6. Electric Bike Throttle Replacement: 步骤 6 中的图像 1,1
    • Track the throttle wire.
    • To ensure you don't lose it, you should mark it.
  7. Electric Bike Throttle Replacement: 步骤 7 中的图像 1,1
    • Locate the throttle wire.
    • Disconnect the throttle wire plug from the controller wire plug.
    • Take caution while handling these wires. You can easily damage them.
结论
Ali Al-hamadani
于10/06/22注册
145 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 44
总计 1,877
