跳转到主内容
Eleaf iJust 3 Disassembly
你所需要的
  1. Eleaf iJust 3 Disassembly, Eleaf iJust 3 Teardown: 步骤 1 中的图像 1,1
    • Specification of iJust 3:
    • Resistance range: 0.1 Ohm - 3.0 Ohm
    • Battery voltage: 3.7V
    • Max power: 80W
  2. Eleaf iJust 3 Disassembly: 步骤 2 中的图像 1,2 Eleaf iJust 3 Disassembly: 步骤 2 中的图像 2,2
    • Insert stick into vice (attach it to the top part) and slowly pull up by "tube part"
    • Be carefull! If you will pull it too fast and too strong, you can break away battery
  3. Eleaf iJust 3 Disassembly: 步骤 3 中的图像 1,1
    • Unscrew two screws on the sides of board.
  4. Eleaf iJust 3 Disassembly: 步骤 4 中的图像 1,1
    • Thats all, thanks for your attention
终点
5等其他人完成本指南。
2条评论
It was very helpful, thank you!
kali1902 - 回复
I don’t think Ifixit should be hosting repair guides for products that can damage your health.
guardian10 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 63
总计 5,114
