跳转到主内容
Eightarc Fusion Joystick Replacement
你所需要的
  1. Eightarc Fusion Joystick Replacement, Joystick: 步骤 1 中的图像 1,2 Eightarc Fusion Joystick Replacement, Joystick: 步骤 1 中的图像 2,2
    • Because of the protruding joystick on the top of the controller, make sure to work on a soft surface or prop the controller up to avoid stress on the joystick.
    • Place the controller face down (buttons and joystick down).
    • Use a Phillips Head #1 screwdriver to remove the eight 9.65mm screws located on the felt and metal backplate.
    • Do not confuse the four screws in the rubber feet with the eight screws in the felt. The screws in the feet do not need to be removed.
  2. Eightarc Fusion Joystick Replacement: 步骤 2 中的图像 1,1
    • Open the door for the cord storage compartment on the right side of the device.
    • Reach under the panel and push upwards on the back panel. Lift it up and remove it from the device.
  3. Eightarc Fusion Joystick Replacement: 步骤 3 中的图像 1,2 Eightarc Fusion Joystick Replacement: 步骤 3 中的图像 2,2
    • Use the large plastic opening tool to softly pry the lip on the white 5 pin connector to relieve pressure while pulling the 5 pin connector.
    • Remove the white connector from the microswitch assembly.
  4. Eightarc Fusion Joystick Replacement: 步骤 4 中的图像 1,2 Eightarc Fusion Joystick Replacement: 步骤 4 中的图像 2,2
    • Insert a #4 Flat Head screwdriver into the shaft of the joystick and grasp the ball topper with your other hand.
    • Turn the flat head screwdriver counter clockwise for a quarter turn while tightly holding the ball topper.
    • The ball topper should now be loose enough to unscrew by hand.
    • Set aside the shaft cover, dust cover, and ball topper.
  5. Eightarc Fusion Joystick Replacement: 步骤 5 中的图像 1,2 Eightarc Fusion Joystick Replacement: 步骤 5 中的图像 2,2
    • Remove the four 8.35 mm screws from the mounting plate of the joystick using a Phillips Head #2 screwdriver.
    • Remove the joystick assembly from the controller.
  6. Eightarc Fusion Joystick Replacement: 步骤 6 中的图像 1,3 Eightarc Fusion Joystick Replacement: 步骤 6 中的图像 2,3 Eightarc Fusion Joystick Replacement: 步骤 6 中的图像 3,3
    • Place joystick assembly on a hard, flat surface.
    • Gently press on the four black tabs on each side of the assembly.
    • With the tabs depressed, lift the clear restrictor plate from the assembly.
  7. Eightarc Fusion Joystick Replacement: 步骤 7 中的图像 1,1
    • Remove the switch housing from the assembly by lifting straight up.
    • The joystick assembly is now ready to be replaced or cleaned.
结论
另外一个人完成了本指南。
Austin
于01/28/15注册
245 声望
创作了2篇指南
团队
Cal Poly, Team 17-35, Amido Winter 2015 Cal Poly, Team 17-35, Amido Winter 2015 的会员
CPSU-AMIDO-W15S17G35
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 813
