跳转到主内容
Eightarc Fusion Headphone Jack Replacement
你所需要的
  1. Eightarc Fusion Headphone Jack Replacement, Headphone Jack: 步骤 1 中的图像 1,2 Eightarc Fusion Headphone Jack Replacement, Headphone Jack: 步骤 1 中的图像 2,2
    • Because of the protruding joystick on the top of the controller, make sure to work on a soft surface or prop the controller up to avoid stress on the joystick.
    • Place the controller face down (buttons and joystick down).
    • Use a Phillips Head #1 screwdriver to remove the eight 9.65mm screws located on the felt and metal backplate.
    • Do not confuse the four screws in the rubber feet with the eight screws in the felt. The screws in the feet do not need to be removed.
  2. Eightarc Fusion Headphone Jack Replacement: 步骤 2 中的图像 1,1
    • Open the door for the cord storage compartment on the right side of the device.
    • Reach under the panel and push upwards on the back panel. Lift it up and remove it from the device.
  3. Eightarc Fusion Headphone Jack Replacement: 步骤 3 中的图像 1,2 Eightarc Fusion Headphone Jack Replacement: 步骤 3 中的图像 2,2
    • Grasp the white plug connecting the wires to the headphone jack, and pull gently upwards.
  4. Eightarc Fusion Headphone Jack Replacement: 步骤 4 中的图像 1,1
    • Using a Phillips head #1 screwdriver, remove the two washer head screws from the headphone jack.
  5. Eightarc Fusion Headphone Jack Replacement: 步骤 5 中的图像 1,2 Eightarc Fusion Headphone Jack Replacement: 步骤 5 中的图像 2,2
    • Gently wiggle the headphone jack left and right, pulling it towards you until it slides out of the hole in the enclosure.
结论
Christopher
于01/29/15注册
133 声望
撰写一个指南
团队
Cal Poly, Team 17-35, Amido Winter 2015 Cal Poly, Team 17-35, Amido Winter 2015 的会员
CPSU-AMIDO-W15S17G35
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 206
