简介
This guide will show you how to replace the LCD of your tablet. It is important to figure out which part of your device is actually broken before you proceed.
你所需要的
Power down your device.
Place the small suction cup on a corner of the screen and lightly pull up to expose a seam between the screen and case.
Remove the battery (secured by six screws and a white wire connector) by following the removal portion of this battery replacement guide.
结论
To reassemble your device, apply glue to the LCD and to the screen, press together, and follow these instructions in reverse order.
