简介
The charging port of your device can fail due to hard impact or general fatigue from repeated use. After purchasing a new charging port and following this guide, your device will be ready to work for you again.
你所需要的
Power down your device.
Place the small suction cup on a corner of the screen and lightly pull up to expose a seam between the screen and case.
Remove the battery (secured by six screws and a white wire connector) by following the removal portion of this battery replacement guide.
With a Phillips #00 screwdriver, remove the one 3.8 mm screw in the LED chip. The LED chip is a small green chip (about 1 square centimeter) located at the top center of the device.
Gently remove the chip with a pair of precision tweezers by grabbing the chip from one side, being careful not to pinch on a black piece of hardware on the chip.
With precision tweezers, pull back the strip of black tape covering the connection between the button key switch and the motherboard.
Disconnect the wires by using precision tweezers to gently pushing the black plug out of the white receptacle.
Disengage the right side of the motherboard by gently sliding the audio jack out of the device case.
With one hand, gently pull the wall of the device outward. With your other hand, pull the motherboard and audio jack to the inside.
Remove the motherboard by lifting the right side, and sliding the motherboard slightly to the right to free the left edge.
With precision tweezers, peel back the yellow tape in the center of the motherboard to expose the ribbon cable to the charging port.
Lift the tan tab on the back of the ribbon cable port upward 90 degrees with a narrow plastic opening tool.
Pull the ribbon cable out of the port, freeing it from the motherboard.
