跳转到主内容
Edwin the Duck Rubber Heart Power Button Replacement
你所需要的
  1. Edwin the Duck Rubber Heart Power Button Replacement, Rubber Heart Power Button: 步骤 1 中的图像 1,2 Edwin the Duck Rubber Heart Power Button Replacement, Rubber Heart Power Button: 步骤 1 中的图像 2,2
    • Unscrew the four 9mm screws with a T8 bit
    • Remove the back plate off
  2. Edwin the Duck Rubber Heart Power Button Replacement: 步骤 2 中的图像 1,2 Edwin the Duck Rubber Heart Power Button Replacement: 步骤 2 中的图像 2,2
    • Carefully take off the rubber skin.
    • It's important to remember to be patient and not rush. You don't want to rip or damage the rubber skin in then resulting in not having a waterproof cover.
  3. Edwin the Duck Rubber Heart Power Button Replacement: 步骤 3 中的图像 1,1
    • Using the J1 bit, unscrew all six 9 mm screws that run along the border.
  4. Edwin the Duck Rubber Heart Power Button Replacement: 步骤 4 中的图像 1,2 Edwin the Duck Rubber Heart Power Button Replacement: 步骤 4 中的图像 2,2
    • Use the plastic opening tool to open the inside of the duck.
    • Be very careful when splitting the two halves apart. There are wires connecting to both sides. Remember to open slowly.
  5. Edwin the Duck Rubber Heart Power Button Replacement: 步骤 5 中的图像 1,2 Edwin the Duck Rubber Heart Power Button Replacement: 步骤 5 中的图像 2,2
    • Using the plastic opening tool pull up the black tab up until it stops.
    • Be careful not to pull up the black tab too far up, otherwise the cable won't be secure anymore.
    • Pull up the white cable tab up slowly
  6. Edwin the Duck Rubber Heart Power Button Replacement: 步骤 6 中的图像 1,2 Edwin the Duck Rubber Heart Power Button Replacement: 步骤 6 中的图像 2,2
    • Use the J1 bit to unscrew all four 9 mm screws connected to the motherboard.
    • Use the J1 bit to unscrew both 9 mm screws attached to the white plastic plate
  7. Edwin the Duck Rubber Heart Power Button Replacement: 步骤 7 中的图像 1,1
    • Lift up the motherboard and speaker and place it away and to the side like you see in the picture
  8. Edwin the Duck Rubber Heart Power Button Replacement: 步骤 8 中的图像 1,2 Edwin the Duck Rubber Heart Power Button Replacement: 步骤 8 中的图像 2,2
    • Unscrew the two black 9 mm screws by using the J1 bit.
    • Remove the damaged rubber heart button and replace with a new rubber heart button.
结论
2等其他人完成本指南。
团队
UW Tacoma, Team S1-G4, Rose Fall 2017 UW Tacoma, Team S1-G4, Rose Fall 2017 的会员
UWT-ROSE-F17S1G4
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 705
