跳转到主内容
Edwin the Duck Rubber Gasket Seal Replacement
你所需要的
  1. Edwin the Duck Rubber Gasket Seal Replacement, Rubber Gasket Seal: 步骤 1 中的图像 1,2 Edwin the Duck Rubber Gasket Seal Replacement, Rubber Gasket Seal: 步骤 1 中的图像 2,2
    • Unscrew the four 9mm screws with aT8 bit
    • Take the back plate off
  2. Edwin the Duck Rubber Gasket Seal Replacement: 步骤 2 中的图像 1,2 Edwin the Duck Rubber Gasket Seal Replacement: 步骤 2 中的图像 2,2
    • Carefully take off the rubber skin.
    • Be patient and don't rush. You don't want to rip or damage the rubber skin otherwise you will lose the waterproof cover.
  3. Edwin the Duck Rubber Gasket Seal Replacement: 步骤 3 中的图像 1,1
    • Using the J1 bit, unscrew all six 9 mm screws around the border.
  4. Edwin the Duck Rubber Gasket Seal Replacement: 步骤 4 中的图像 1,2 Edwin the Duck Rubber Gasket Seal Replacement: 步骤 4 中的图像 2,2
    • Use the plastic opening tool to open the inside of the duck.
    • Be very careful when splitting the two halves apart. There are wires connecting to both sides. So open it very slowly.
  5. Edwin the Duck Rubber Gasket Seal Replacement: 步骤 5 中的图像 1,2 Edwin the Duck Rubber Gasket Seal Replacement: 步骤 5 中的图像 2,2
    • Remove the rubber gasket
  6. Edwin the Duck Rubber Gasket Seal Replacement: 步骤 6 中的图像 1,1
    • Insert your new rubber gasket in and use the plastic opening tool to push the rubber gasket into it's slot
结论
团队
UW Tacoma, Team S1-G4, Rose Fall 2017 UW Tacoma, Team S1-G4, Rose Fall 2017 的会员
UWT-ROSE-F17S1G4
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 9
总计 326
