跳转到主内容
Edwin the Duck Motherboard Replacement
你所需要的
  1. Edwin the Duck Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,2 Edwin the Duck Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,2
    • Unscrew the four 9mm screws with a T8 screwdriver bit
    • Remove the back plate off
  2. Edwin the Duck Motherboard Replacement: 步骤 2 中的图像 1,2 Edwin the Duck Motherboard Replacement: 步骤 2 中的图像 2,2
    • Carefully take off the rubber skin.
    • Be patient and don't rush. You don't want to rip or damage the rubber skin resulting in losing the waterproof cover.
  3. Edwin the Duck Motherboard Replacement: 步骤 3 中的图像 1,1
    • Using the J1 screwdriver bit, unscrew all six 9 mm screws that run along the border.
  4. Edwin the Duck Motherboard Replacement: 步骤 4 中的图像 1,2 Edwin the Duck Motherboard Replacement: 步骤 4 中的图像 2,2
    • Use the plastic opening tool to open the inside of the duck.
    • Be very careful when splitting the two halves apart. There are wires connecting to both sides. Remember to open slowly.
  5. Edwin the Duck Motherboard Replacement: 步骤 5 中的图像 1,2 Edwin the Duck Motherboard Replacement: 步骤 5 中的图像 2,2
    • Using the plastic opening tool pull up the black tab up until it stops.
    • Be careful not to pull up the black tab too far up, otherwise the cable won't be secure anymore.
    • Pull up the white cable tab, up slowly
  6. Edwin the Duck Motherboard Replacement: 步骤 6 中的图像 1,1
    • Use the J1 screwdriver bit to unscrew all four 9 mm screws attached to the motherboard.
  7. Edwin the Duck Motherboard Replacement: 步骤 7 中的图像 1,1
    • Remove the top connector as you see in the picture.
    • Replace the new motherboard and you are finished.
结论
另外一个人完成了本指南。
Caleb Kim
于10/18/17注册
143 声望
撰写一个指南
团队
UW Tacoma, Team S1-G4, Rose Fall 2017 UW Tacoma, Team S1-G4, Rose Fall 2017 的会员
UWT-ROSE-F17S1G4
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 400
