跳转到主内容
Ecovacs Deebot 900 Wheel Replacement
你所需要的
  1. Ecovacs Deebot 900 Wheel Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove all the brushes from the Deebot.
  2. Ecovacs Deebot 900 Wheel Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips #0 screwdriver, remove the two 12.25 mm screws holding the battery cover in place.​
  3. Ecovacs Deebot 900 Wheel Replacement: 步骤 3 中的图像 1,1
    • Remove the battery cover.
  4. Ecovacs Deebot 900 Wheel Replacement: 步骤 4 中的图像 1,1
    • Using the two white straps on the sides of the battery, gently remove the battery. ​
    • Be careful not to rip out the battery cable.
  5. Ecovacs Deebot 900 Wheel Replacement: 步骤 5 中的图像 1,1
    • Carefully disconnect the battery cable by pulling near the connector at the bottom of the battery compartment.
  6. Ecovacs Deebot 900 Wheel Replacement, Front Bumper: 步骤 6 中的图像 1,2 Ecovacs Deebot 900 Wheel Replacement, Front Bumper: 步骤 6 中的图像 2,2
    • Using a Phillips #00 screwdriver, remove the eight screws on the bottom edge of the bumper. ​
  7. Ecovacs Deebot 900 Wheel Replacement: 步骤 7 中的图像 1,1
    • Remove the black strip on the bottom of the bumper.
  8. Ecovacs Deebot 900 Wheel Replacement: 步骤 8 中的图像 1,2 Ecovacs Deebot 900 Wheel Replacement: 步骤 8 中的图像 2,2
    • Carefully lift up the bumper untill it pops out of place.​
  9. Ecovacs Deebot 900 Wheel Replacement: 步骤 9 中的图像 1,2 Ecovacs Deebot 900 Wheel Replacement: 步骤 9 中的图像 2,2
    • Disconnect the two cables connecting the bumper to the body of the Deebot.
    • Remove the front bumper from the device.
  10. Ecovacs Deebot 900 Wheel Replacement, Bottom Case: 步骤 10 中的图像 1,2 Ecovacs Deebot 900 Wheel Replacement, Bottom Case: 步骤 10 中的图像 2,2
    • Using a Phillips #00 screwdriver, take out the six screws around the perimeter of the bottom case.
  11. Ecovacs Deebot 900 Wheel Replacement: 步骤 11 中的图像 1,2 Ecovacs Deebot 900 Wheel Replacement: 步骤 11 中的图像 2,2
    • Insert a Jimmy into the seam and work all the way around the robot.
    • Disconnect the two cables and remove the bottom case from the device.
  12. Ecovacs Deebot 900 Wheel Replacement, Motherboard: 步骤 12 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove the two black screws holding the motherboard in place.​
  13. Ecovacs Deebot 900 Wheel Replacement: 步骤 13 中的图像 1,1
    • Carefully remove the ribbon cables connected to the top of motherboard.
    • Keep track of where the cables connect to the motherboard.
  14. Ecovacs Deebot 900 Wheel Replacement: 步骤 14 中的图像 1,1
    • Remove the last three ribbon cables on the underside of the motherboard.​
  15. Ecovacs Deebot 900 Wheel Replacement: 步骤 15 中的图像 1,1
    • Lift the motherboard out of the Deebot and remove it from the device.
  16. Ecovacs Deebot 900 Wheel Replacement, Wheel: 步骤 16 中的图像 1,1
    • Using a screwdriver or tweezers, remove the spring by lifting the spring and pulling it off one side.
  17. Ecovacs Deebot 900 Wheel Replacement: 步骤 17 中的图像 1,2 Ecovacs Deebot 900 Wheel Replacement: 步骤 17 中的图像 2,2
    • Using a Phillips #00 screwdriver, remove the four screws holding the wheel assembly in place.
  18. Ecovacs Deebot 900 Wheel Replacement: 步骤 18 中的图像 1,1
    • Remove the wheel cover.
  19. Ecovacs Deebot 900 Wheel Replacement: 步骤 19 中的图像 1,3 Ecovacs Deebot 900 Wheel Replacement: 步骤 19 中的图像 2,3 Ecovacs Deebot 900 Wheel Replacement: 步骤 19 中的图像 3,3
    • Using the Phillips #00 screwdriver, remove the three screws holding the side brush motor in place and lift the brush motor up.
  20. Ecovacs Deebot 900 Wheel Replacement: 步骤 20 中的图像 1,2 Ecovacs Deebot 900 Wheel Replacement: 步骤 20 中的图像 2,2
    • Lift up and remove the wheel assembly and the attached sensor (black cable).
结论
6等其他人完成本指南。
6条评论
Thanks, it helps a lot
Agoston David - 回复
I have an OZMO 930 that the left driver wheel is stuck. I tried to follow the above instruction, but I can’t go beyond step 10, I can’t take out the cover. Any help will be greatly appreciated,
OldManInChicago - 回复
do you have place to buy ecovac_deebot_900_54_gear ?? I thinking on printing it but after my printed gear to papper shreder I have no hopes it will last.
Plewu Gracz - 回复
Thanks for the guide on the Deebot 900 wheel replacement. Though it has partially helps to resolve the problems, but unable to find a wheel replacement. Hope you can help too.
wong CS - 回复
The rubber tires on my Deebot have worn through. Does anybody have a source for rubber tire replacement? The company wants to sell me two entire wheel assemblies. I find that unreasonable.
akobelan - 回复
添加评论
浏览统计数据:
过去 24 小时: 22
过去 7 天: 160
过去 30 天: 702
总计 42,793
