跳转到主内容
Ecovacs Deebot 900 Motherboard Replacement
你所需要的
  1. Ecovacs Deebot 900 Motherboard Replacement, Front Bumper: 步骤 1 中的图像 1,2 Ecovacs Deebot 900 Motherboard Replacement, Front Bumper: 步骤 1 中的图像 2,2
    • Using a Phillips #00 screwdriver, remove the eight screws on the bottom edge of the bumper. ​
  2. Ecovacs Deebot 900 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the black strip on the bottom of the bumper.
  3. Ecovacs Deebot 900 Motherboard Replacement: 步骤 3 中的图像 1,2 Ecovacs Deebot 900 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Carefully lift up the bumper untill it pops out of place.​
  4. Ecovacs Deebot 900 Motherboard Replacement: 步骤 4 中的图像 1,2 Ecovacs Deebot 900 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Disconnect the two cables connecting the bumper to the body of the Deebot.
    • Remove the front bumper from the device.
  5. Ecovacs Deebot 900 Motherboard Replacement, Bottom Case: 步骤 5 中的图像 1,2 Ecovacs Deebot 900 Motherboard Replacement, Bottom Case: 步骤 5 中的图像 2,2
    • Using a Phillips #00 screwdriver, take out the six screws around the perimeter of the bottom case.
  6. Ecovacs Deebot 900 Motherboard Replacement: 步骤 6 中的图像 1,2 Ecovacs Deebot 900 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Insert a Jimmy into the seam and work all the way around the robot.
    • Disconnect the two cables and remove the bottom case from the device.
  7. Ecovacs Deebot 900 Motherboard Replacement, Motherboard: 步骤 7 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove the two black screws holding the motherboard in place.​
  8. Ecovacs Deebot 900 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Carefully remove the ribbon cables connected to the top of motherboard.
    • Keep track of where the cables connect to the motherboard.
  9. Ecovacs Deebot 900 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Remove the last three ribbon cables on the underside of the motherboard.​
  10. Ecovacs Deebot 900 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Lift the motherboard out of the Deebot and remove it from the device.
结论
4等其他人完成本指南。
2条评论
Any suggestions on purchase options?
Curtis Tyler - 回复
vakum ozmo 900,hidup terus mati,lampu led juga mati,switch masih posisi on
markus arif - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 30
过去 30 天: 182
总计 7,114
