跳转到主内容
Ecovacs Deebot 900 Bottom Case Replacement
你所需要的
  1. Ecovacs Deebot 900 Bottom Case Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove all the brushes from the Deebot.
  2. Ecovacs Deebot 900 Bottom Case Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips #0 screwdriver, remove the two 12.25 mm screws holding the battery cover in place.​
  3. Ecovacs Deebot 900 Bottom Case Replacement: 步骤 3 中的图像 1,1
    • Remove the battery cover.
  4. Ecovacs Deebot 900 Bottom Case Replacement: 步骤 4 中的图像 1,1
    • Using the two white straps on the sides of the battery, gently remove the battery. ​
    • Be careful not to rip out the battery cable.
  5. Ecovacs Deebot 900 Bottom Case Replacement: 步骤 5 中的图像 1,1
    • Carefully disconnect the battery cable by pulling near the connector at the bottom of the battery compartment.
  6. Ecovacs Deebot 900 Bottom Case Replacement, Front Bumper: 步骤 6 中的图像 1,2 Ecovacs Deebot 900 Bottom Case Replacement, Front Bumper: 步骤 6 中的图像 2,2
    • Using a Phillips #00 screwdriver, remove the eight screws on the bottom edge of the bumper. ​
  7. Ecovacs Deebot 900 Bottom Case Replacement: 步骤 7 中的图像 1,1
    • Remove the black strip on the bottom of the bumper.
  8. Ecovacs Deebot 900 Bottom Case Replacement: 步骤 8 中的图像 1,2 Ecovacs Deebot 900 Bottom Case Replacement: 步骤 8 中的图像 2,2
    • Carefully lift up the bumper untill it pops out of place.​
  9. Ecovacs Deebot 900 Bottom Case Replacement: 步骤 9 中的图像 1,2 Ecovacs Deebot 900 Bottom Case Replacement: 步骤 9 中的图像 2,2
    • Disconnect the two cables connecting the bumper to the body of the Deebot.
    • Remove the front bumper from the device.
  10. Ecovacs Deebot 900 Bottom Case Replacement, Bottom Case: 步骤 10 中的图像 1,2 Ecovacs Deebot 900 Bottom Case Replacement, Bottom Case: 步骤 10 中的图像 2,2
    • Using a Phillips #00 screwdriver, take out the six screws around the perimeter of the bottom case.
  11. Ecovacs Deebot 900 Bottom Case Replacement: 步骤 11 中的图像 1,2 Ecovacs Deebot 900 Bottom Case Replacement: 步骤 11 中的图像 2,2
    • Insert a Jimmy into the seam and work all the way around the robot.
    • Disconnect the two cables and remove the bottom case from the device.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 27
总计 2,295
