跳转到主内容
Ecovacs Deebot 900 Battery Replacement
你所需要的
  1. Ecovacs Deebot 900 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove all the brushes from the Deebot.
  2. Ecovacs Deebot 900 Battery Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips #0 screwdriver, remove the two 12.25 mm screws holding the battery cover in place.​
  3. Ecovacs Deebot 900 Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the battery cover.
  4. Ecovacs Deebot 900 Battery Replacement: 步骤 4 中的图像 1,1
    • Using the two white straps on the sides of the battery, gently remove the battery. ​
    • Be careful not to rip out the battery cable.
  5. Ecovacs Deebot 900 Battery Replacement: 步骤 5 中的图像 1,1
    • Carefully disconnect the battery cable by pulling near the connector at the bottom of the battery compartment.
结论
5等其他人完成本指南。
5条评论
Great guide except no information on where to actually FIND a battery for this thing
Chris Staley - 回复
Where can replacement battery packs be acquired from?
Larry Smith - 回复
You can find the battery at Taobao online shopping
Jimmy - 回复
Amazon also sells them. Make sure to get one for the correct model though (there are alot of them)
Kevin Dunn - 回复
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 105
过去 30 天: 426
总计 22,205
