跳转到主内容
Ecovacs DEEBOT D35 Vacuum Motor Replacement
你所需要的
  1. Ecovacs DEEBOT D35 Vacuum Motor Replacement, Vacuum Motor: 步骤 1 中的图像 1,1
    • Lay the Deebot face down so you have access to the battery compartment. Remove the battery.
  2. Ecovacs DEEBOT D35 Vacuum Motor Replacement: 步骤 2 中的图像 1,1
    • Locate the 9 screws that secure the back cover. Remove with a PH2 Phillips Head Screwdriver. The screws are:
    • 7 x 14mm screws
    • 2 x 10mm screws
  3. Ecovacs DEEBOT D35 Vacuum Motor Replacement: 步骤 3 中的图像 1,1
    • Use a spudger or plastic opening tool to separate the Deebot backside.
  4. Ecovacs DEEBOT D35 Vacuum Motor Replacement: 步骤 4 中的图像 1,1
    • Carefully lift the back cover from the body of the Deebot to expose the internal wiring harnesses.
  5. Ecovacs DEEBOT D35 Vacuum Motor Replacement: 步骤 5 中的图像 1,1
    • There are 5 wiring harnesses that need to be disconnected before completely removing the back cover.
    • There are two blue wiring harnesses on the front left and right side (located next to the sensor). They are represented by the red circles.
    • There is a multicolor wiring harness on the front center. This is represented by the orange circle.
    • Two black and red wiring harnesses are connected to the motherboard. This is represented by the yellow circles.
  6. Ecovacs DEEBOT D35 Vacuum Motor Replacement: 步骤 6 中的图像 1,1
    • Locate the 4 screws on the vacuum motor.
  7. Ecovacs DEEBOT D35 Vacuum Motor Replacement: 步骤 7 中的图像 1,1
    • Remove the screws from the vacuum motor body with a PH2 Phillips Head Screwdriver. The screws are:
    • 4 x 10mm screws
  8. Ecovacs DEEBOT D35 Vacuum Motor Replacement: 步骤 8 中的图像 1,1
    • Remove the vacuum motor body
结论
3等其他人完成本指南。
Brian
于02/15/17注册
475 声望
创作了3篇指南
团队
USF Tampa, Team 12-2, Eyestone Spring 2017 USF Tampa, Team 12-2, Eyestone Spring 2017 的会员
USFT-EYESTONE-S17S12G2
4 名成员
创作了4篇指南
一条评论
thanks a lots for the valuable info
sk law - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 18
总计 9,014
