跳转到主内容
Eco X Gear Voice Coil Replacement
你所需要的
  1. Eco X Gear Voice Coil Replacement, Frame: 步骤 1 中的图像 1,1
    • Disconnect any power source and/or turn off device.
  2. Eco X Gear Voice Coil Replacement: 步骤 2 中的图像 1,1
    • Remove the 15 rubber plugs from the cavities using needle nose pliers.
  3. Eco X Gear Voice Coil Replacement: 步骤 3 中的图像 1,1
    • Use a phillips head screwdriver to remove the fifteen 6.4mm screws.
  4. Eco X Gear Voice Coil Replacement: 步骤 4 中的图像 1,1
    • Carefully separate the two sections of the frame.
    • Wires still connect the two sections. Be cautious to avoid damaging the wires, terminals, and electronics.
  5. Eco X Gear Voice Coil Replacement, Voice Coil: 步骤 5 中的图像 1,1
    • Disconnect the wiring to improve accessibility to the cones.
  6. Eco X Gear Voice Coil Replacement: 步骤 6 中的图像 1,2 Eco X Gear Voice Coil Replacement: 步骤 6 中的图像 2,2
    • Remove the four screws that hold down the speaker and pry up the speaker from the frame.
  7. Eco X Gear Voice Coil Replacement: 步骤 7 中的图像 1,1
    • Once the voice coil is removed, solder it back onto the bracket or replace the voice coil entirely.
结论
James Lipsett
于03/20/17注册
625 声望
创作了6篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 13
总计 184
